akdrtfan
Post by akdrtfan on Apr 16, 2007 13:21:03 GMT 9
Does anyone know what happened to NASA's F-106 they flew? I have seen pictures of it in some of the F-106 books.
Post by Mark O on Apr 16, 2007 13:26:24 GMT 9
Does anyone know what happened to NASA's F-106 they flew? I have seen pictures of it in some of the F-106 books. One is hanging from the ceiling at the Virginia Air & Space Center in Hampton, Virginia. Go to the preserved pages for 57-2516 on the main page! Mark
Post by Cougar on Apr 16, 2007 13:35:44 GMT 9
57-2507 (NF-106 B) assigned to NASA, Langley, VA as NASA #607. Final Disposition, Cut in Half - lengthwise - to accommodate Wind Tunnel Testing of Vortex Flap. Aircraft never assigned to ADC. 57-2519 (NF-106 B) & 57-2529 (NF-106 B) Both acft used for NASA Variable Stability Testing; Retired 21 Oct 71; (14 Sep 76, return to CC status-cost prohibitive; dropped from inventory as surplus) Cannibalized for parts at McClellan AFB. picture of both acft @ SM-ALC: www.f-106deltadart.com/depot-smalc.htm
Post by Cougar on Apr 23, 2007 3:10:29 GMT 9
59-0010; (NF-106 A) NASA Eclipse Tow Test (Back-up Aircraft) (Initial DFI by conversion to QF-106A.) Final to AMARC on 05/12/98 59-0130; (NF-106 A) NASA Eclipse Tow Test (Primary Aircraft) (Initial DFI by conversion to QF-106A.) Final to AMARC on 05/01/98 Eclipse Flight Videos @ www.dfrc.nasa.gov/Gallery/Movie/Eclipse/index.html
Post by Mark O on Apr 23, 2007 13:41:31 GMT 9
Ron Dot'o
Post by Ron Dot'o on Sept 21, 2007 23:32:08 GMT 9
Back around '72 NASA had a 6 at Selfridge ANGB, MI that was a tri motor. It had a small experimental jet engine under each wing. I was at Langly in '88 during an open house and they had a NASA 6 there as a static display. The guy manning the static display told me that that was the 6 from SANGB that used to be a tri motor and was now involved in a project where they flew it into thunderstorms to have lightning strike it for some kind of research. I forget what the tail # was. I have no idea of its final fate.
Ron D
Post by Black Bart on Sept 22, 2007 3:15:32 GMT 9
NASA donated the naked (no paint) "B" model to the Hampton Air and Space Museum. It was hit by lightning over 200 times.
The one that was cut in half in known as the F-53 Delta Dart. Black Bart
Post by Cougar on Sept 22, 2007 3:21:05 GMT 9
