Post by MOW on Mar 11, 2007 20:11:49 GMT 9
A guestbook entry from a guy in Russia has a Forum and is looking for "Bear" intercept pilots. This is the only English board on the forum, but the guys there seem pretty well engaged in. fedotovoruhelpc.ruhelp.com/index.php?s=b79789f33987579f78251e0f23b83f47&showforum=23Another of his boards has photo's of different aircraft escorting Bears. fedotovoruhelpc.ruhelp.com/index.php?showtopic=88 one being the 119th Six photo. Granted the forum buttons are all in Russian, but they have the standard type icons on them to indicate what they do. Here are some of them with explanations: = Post a Reply = Post a Reply with the original message in Quotes - Submit Button after writing a Post = Edit your Post = Submit Changes after you Edit your Post
Post by MOW on Mar 18, 2007 7:41:36 GMT 9
Not many hits on this. I've been over to his site several times and the guys there seem to engage in some interesting conversation. Granted the forum buttons are all in Russian, but they have the standard type icons on them to indicate what they do. Here are some of them with explanations: = Post a Reply = Post a Reply with the original message in Quotes - Submit Button after writing a Post = Edit your Post = Submit Changes after you Edit your Post
Post by ma1marv on Mar 18, 2007 10:44:52 GMT 9
WHHAAAATTTT!!!!!! You mean you don't have your translater working??? I do!! It does a double inside translation of every thing!! I simply highlite the word, the translater takes over! It translates the unknown word into Greek, then Korean, then German, then shifts everything using Grey Code and translates the whole mess into hexidecimal code! Which I happen to be very good at! As a matter of fact, ALL MA-1 troops are good at Hex and Octal conversions! Thank you! I then translate manually into octal, then BCD and then to binary coded ASCII! That goes into the mixer and out comes the most perfect English/Irish/Gaelic crap you've ever seen!!! Happy ST PATRICKS day every one!!! MArv
Post by MOW on Mar 18, 2007 14:16:05 GMT 9
WHHAAAATTTT!!!!!! You mean you don't have your translater working??? I do!! It does a double inside translation of every thing!! I simply highlite the word, the translater takes over! It translates the unknown word into Greek, then Korean, then German, then shifts everything using Grey Code and translates the whole mess into hexidecimal code! Which I happen to be very good at! As a matter of fact, ALL MA-1 troops are good at Hex and Octal conversions! Thank you! I then translate manually into octal, then BCD and then to binary coded ASCII! That goes into the mixer and out comes the most perfect English/Irish/Gaelic crap you've ever seen!!! Happy ST PATRICKS day every one!!! MArv Oh yea that's the same translater I use when Jim posts , nothing else seems to work
Post by Mark O on Mar 19, 2007 8:53:41 GMT 9
WHHAAAATTTT!!!!!! You mean you don't have your translater working??? I do!! It does a double inside translation of every thing!! I simply highlite the word, the translater takes over! It translates the unknown word into Greek, then Korean, then German, then shifts everything using Grey Code and translates the whole mess into hexidecimal code! Which I happen to be very good at! As a matter of fact, ALL MA-1 troops are good at Hex and Octal conversions! Thank you! I then translate manually into octal, then BCD and then to binary coded ASCII! That goes into the mixer and out comes the most perfect English/Irish/Gaelic crap you've ever seen!!! Happy ST PATRICKS day every one!!! MArv Oh. Gee whiz, why didn't I think of that?!! Honestly Marv that's a pretty cool site as we know. I just cracked up when I read your post. Mark
Post by Jim on Mar 19, 2007 11:51:19 GMT 9
Post by Cougar on Apr 25, 2007 2:24:34 GMT 9
WHHAAAATTTT!!!!!! You mean you don't have your translater working??? I do!! It does a double inside translation of every thing!! I simply highlite the word, the translater takes over! It translates the unknown word into Greek, then Korean, then German, then shifts everything using Grey Code and translates the whole mess into hexidecimal code! Which I happen to be very good at! As a matter of fact, ALL MA-1 troops are good at Hex and Octal conversions! Thank you! I then translate manually into octal, then BCD and then to binary coded ASCII! That goes into the mixer and out comes the most perfect English/Irish/Gaelic crap you've ever seen!!! MArv Way to go MArv, ole Hextor got into da Octalernal and then the Kerflumpter took over an translated everthin inta der A$$key stuff, but it still don't solve the international problem we be dealing with here: If Russia attacked Turkey from the rear, would Greece help?
