Post by delta2477a on Aug 4, 2005 10:42:50 GMT 9
It doesn't seem to be your usual convergent-divergent engine-nozzle that you see on ordinary fighters.
Post by Cougar on Aug 4, 2005 16:14:50 GMT 9
It doesn't seem to be your usual convergent-divergent engine-nozzle that you see on ordinary fighters. To my knowledge, the J-75 had the typical convergent-divergent nozzle used on all Pratt-n-Whiskey engines of that time frame. It may be that what you are looking at is the cooling shroud nozzle; the engine nozzle not visible until you were somewhere in the neighborhood of 20 degrees behind the acft, perpendicular to the centerline.
Post by John Bartoszewicz on Aug 5, 2005 0:36:55 GMT 9
The only other thing is you may be seeing the idle thrust reducer that allowed the Six to idle and taxi at proper RPM and still not blow everything around. Jack
Post by Jim on Aug 5, 2005 11:17:37 GMT 9
The only other thing is you may be seeing the idle thrust reducer that allowed the Six to idle and taxi at proper RPM and still not blow everything around. Jack CORRECT..........All a/c after the SIX became anything from strange to wierd and uglier than sin or a SAIGON streetwalker.............The Old Sarge AND for bringin some life to the forum
Post by Cougar on Aug 8, 2005 17:16:17 GMT 9
Post by Jim on Aug 9, 2005 8:03:51 GMT 9
Careful there Old Sarge, some oh dem SAIGON street walkers was lookin pertty beeuutiifulll afer a cuple a 6-pax. [glow=red,2,300] [/glow] BAM-LE- BAM (33) IS WHAT THE LABLE READ AN 2 O THEM SIX PAKS WOULD O PUT YE INA MORGUE......BEST YE BE A DRINKIN ME FINE IRISH BREW WHAT BE INA GREEN BOTTLE The Old Sarge
