Post by Mark O on Sept 5, 2011 3:00:10 GMT 9
Post by bear (Deceased) on Sept 5, 2011 10:50:59 GMT 9
Main Gear Door someone painted that so wuold't run into it. In front of nose gear is a Angel of Attack cover with red flag covering the UHF or TACAN antenna. Bear
Post by Mark O on Sept 5, 2011 10:58:34 GMT 9
Post by LBer1568 on Sept 5, 2011 12:03:17 GMT 9
Mark, It looks like a storage box crew chiefs used to store all the remove before flight streamers. A complete walk around removing them the Pilot would have an arm load. Including door locks, it would be about the right size. Our CC at 539th had similar storage racks. I believe our Sheet metal shop fabricated them.
Post by Mark O on Sept 5, 2011 12:13:11 GMT 9
Mark, It looks like a storage box crew chiefs used to store all the remove before flight streamers. A complete walk around removing them the Pilot would have an arm load. Including door locks, it would be about the right size. Our CC at 539th had similar storage racks. I believe our Sheet metal shop fabricated them. That makes perfect sense! I knew it wasn't a conventional tool box, but it clearly was designed to hold something! (Duh!) Thanks for the info! :thanks
Post by bear (Deceased) on Sept 5, 2011 21:04:06 GMT 9
After I enlarged the picture to 400% and got my eyeballs looking in the right place that is a Door Lock holder. The thing I saw was the AOA cover the covered the Vane for the Gun sight system. It's only been 30 years and the cobb webs are thick,sorry about the error.
Bear
Lee Nellist
Founding Member
Retired: USAF
Post by Lee Nellist on Sept 5, 2011 23:26:31 GMT 9
time does fly.
Lee
