Post by Bullhunter on Oct 22, 2007 9:23:57 GMT 9
Being around aircraft I'm sure most of us have delt with a fuel spill or two. This was my first. Circa 1972 Norton AFB, CA (MAC) It was a lazy Sunday afternoon. ( You expected it to start off like it was a dark & stormy Night !) Anyway another airman and I were changing an engine CSD & Elect generator on #3 engine of a C-141B aircraft. As we worked taking our time we notice the ground got wet and we assumed that wash rack was busy washing an aircraft on the ramp above us. But within and a matter of seconds I knew that was not the case as I smelled jet fuel fumes. I quickly went to the front of the aircraft and looked up the ramp, and parked up at the head of the line 4 aircraft away was an aircraft with a fuel leak out of both wings. Looked like two big water falls. I knew the fuel dump switches had been activated some how even though they had guards over the switches. What made the situation worse was the MD-3 was running so the fuel pumps were pumping it out under preasure and as you remember MD-3's threw sparks out of thier exhausts. I told my co-worker to run to the passanger terminal and a telephone to call for help. I grabed my headsets and took of on a dead run up the ramp through the jet fuel (splash, splash, splash)and boarded the leaking aircraft. Sitting at the flight-engineers table was a SSgt with the aircraft forms closed. I told him we had a massive fuel leak and I leaned over him and flipped fuel dump switches down into the off position and then flipped the guards down. I then jumped into the pilots seat and plugged in my headset and called the control tower and declared a ground emergancy, massive fuel spill. I then told the SSgt crew-chief to kill the aircraft power and battery and I'd shutdown the MD-3 external power unit. As I reached the MD-3 and for it's cutoff switch I stopped as my mind reminded me that these MD-3's like to throw sparks especially on shutdown. So I whipped off my fatigue shirt , cut-off the power unit, and quickly smothered the hot exhaust with my shirt. Preventing sparks. Fuel spill was stopped all power supplies cut, and the MD-3 operation shutdown. No explosion or fire. A line of 5 or 6 C-141 aircraft secured and saved. After the fire trucks arrived the crew chief and I talked. We believe that when the he ( thecrewchief) was reviewing the aircraft forms he pushed the cover under the fuel switches. When he closed the forms; the raising of the cover tripped the fuel dump switches. Nobody ever said thank-you, good job, and they would not even issue me another fatigue shirt. I had to buy a replacement myself. Now, does that not suck ?
Post by lindel on Oct 22, 2007 20:00:21 GMT 9
Not a fuel spill, but had a lightning storm catch a SAC Hill fuel dump on fire. We watched the base fire dept put the thing out easily half a dozen times, all the while not knowing the amount of fuel stored there.
Had we known, we'd have left for safer ground!
bp
Post by bp on Oct 23, 2007 11:14:42 GMT 9
Saw an A-7D come back from a training mission in Tucson. As the crew chief was refueling we could see fuel pumping out of the wing as fast as they were pumping it in. Found out that it had a 13 inch crack in the wing spar. Not long after that the A-7 fleet was mothballed.
Post by Jeff Shannon on Oct 23, 2007 13:37:39 GMT 9
Post by sixerviper on Oct 24, 2007 2:34:56 GMT 9
Hmmm--Two stories, actually, with two different jets. I was an Instrument Weenie at Minot in the summer of 1972, and we had a bad fuel probe on a Six. Couldn't find a crew chief (imagine that!) so after the jet was defueled and depuddled, we had to remove the panel from the BOTTOM of the wing. Of course, "depuddling" does not get the tank dry, as any fuel weenie will tell you, and this was no exception. As I was removing screws and taking a bath in JP-4, a Convair tech rep happened to wander by and I just let him have it about the $hitty design of this jet with the panels on the bottom of the wing and, oh by the way, why in the hell are there fifteen different sizes of screws in the panel, all with the same head size? ?? There I was, soaking wet in fuel, getting a lecture on how the panels were chemically milled to save weight and those screws were NECESSARY so the jet could catch the Russian Bear. I laugh about it now, but it definitely was NOT funny then. On a funnier note, at the Va ANG, I watched two crew chiefs lower an F-105 bomb bay tank they thought was empty...but it wasn't. The D-gear dropped to the limit of its travel (that's the mechanism originally designed to spit out the nuclear bomb in an autoss maneuver), stopped with a jerk, the tank split open, and 370 gallons of JP-4 gushed out of the tank in about two seconds. That was funny--and nobody got in much trouble! They probably would have had his first-born son if they'd done that these days.
Post by Bullhunter on Oct 24, 2007 7:15:14 GMT 9
Yep and the fire truck always came out and washed it down the drain. At Norton I asked somebody once where the grated drains went that crossed our flightline. He said to the dry river bed on the other side of the runway. Ever wonder why when a base closes there is so much talk about enviromental clean ups?
az09
Post by az09 on May 6, 2008 4:28:25 GMT 9
1966 - Dyess AFB, Tx - 516th FMSq - Propulsion Branch - Engine Phase Section
Being part of the troop build up for the SE Asian war we had about 30 new guys in 3 to 5 level up-grade training. That was on top of a bunch of Recip Engine Mechanics that were retrained into Jet engines. They had to do the 3-5-7 training to get to their grade / skill level ratings for promotions.
These guys were the original "OLD" troops. Some were air force but alot were previous ARMY, airborne, rangers and MARINES. Our Branch Chief was a retred from Airborne and one of the first Chief Master Sergeants after the top 2 grades were developed.
My first trainer was one of these guys. I had to lead him through my 623 Training Record to sign me off as I completed tasks. He couldn't read, and would become very withdrawn when I would look him up to do his duty for me.
I worked Phased Inspections, Hanger 5020 as I remember. We would do a stand-up roll-call with the Chief and then be released to get our tool boxes and be driven over to the hanger.
This was the daily routine 5 days aweek. The 4 Ssgt's, 2 TSgt, and MSgt would do all the prep for us to start pulling filters out of the fuel and oil systems.
As we progressed thru the training we would be shown the order of pulling fuses, circuit breakers T-handles, and the Battery switch. We all got the training and were qualified. We were allowed to function freely as the 623 was signed off.
One afternoon we got a bird early from the Flying Squadron. We could get a jump on the work and maybe get Friday afternoon off. We did the intake and exhaust inspections for damage. One of the guys on number 4 was headed to the flight deck to pull the breakers on the fuel and oil systems so we could get on the messy part of phase work, pulling the filters.
I asked Pete if he was going up to pull the breakers. he said yes. I asked him to do number 3 for me. As he rounded the nose of the plane I heard him be asked by the number 1 and 2 guys to pull their breakers too. He said OK!
We all worked about the same speed, did the same filters at about the same time. The oil first so if we found any big chunks of metal we would do the engine change and not expend time and effort on a bad engine.
Came time to do the large low pressure fuel strainer on the right side of the T-56. The strainer body is big, about 6" across. It has a double O-ring seal set-up. I drained the housing with the fuel pitcock and when it just dribbled It was the sign it was empty. I had filled just about a whole bucket with fuel which was a little odd as the strainer doesn't hold that much. So, the number 4 engine was the big phase of the 4 engines this time. They had most of the buckets. I yelled over to ask if I use one of theirs. I went and got one and returned. I "pop" the strainer cap and pull back exposing the first seal. A little fuel dribbles out. I pull the second seal clear of the housing and a gusher of fuel flows freely out of the housing in seconds my bucket is filled and flooding the dock. The number 4 guys yell for me to return their bucket as they have what I have a class A fuel spill in mid happening.
I jab the cap back into the housing, blocking the opening. But the seals have hit air and swollen too large to go back in the housing. The seals look like a big black doily, hanging out of the strainer with a small dribble of fuel. I get the clamp back on the cap and cinch it down.
What happened to me happened on the other 3 engines. Between the four engines we had drained the aircraft of fuel. 5020 was flooded. All the power was cut and the fire trucks were called. The fuel was washed into the floor drains and the APG guys squicheed the rest into the drains. Then the hanger was emptied of aircraft to let the place air out and dry.
We went back to the engine shop in shame. The in-shop guys had already heard and were lined up laughing at us all. The Supervisors were taken to the break room to tell the tale of how this incident happened. The Chief mandated that only a 7-level would enter the flight deck to pull breakers.
We reported back to the Phase Hanger to finish the phase and some "smart-a-- had put a sign on the crew entry door that read, "Dry Clean ONLY!"
The next week the Branch Chief started working on a training plan for the whole Branch.
farranb
FUEL SYSTEM REPAIR
Post by farranb on Dec 19, 2011 7:55:46 GMT 9
Being a retired fuel system repair guy there's way too many spill stories. Let's start one for suffocation, burns and deformities! Why don't you talk about the dumb mistakes that crew members and other maintenance shops do that cause other people to work ungodly hours to fix. Hey, just break it, write it up, and go home.
Post by Jim on Dec 19, 2011 8:25:37 GMT 9
Being a retired fuel system repair guy there's way too many spill stories. Let's start one for suffocation, burns and deformities! Why don't you talk about the dumb mistakes that crew members and other maintenance shops do that cause other people to work ungodly hours to fix. Hey, just break it, write it up, and go home. oohh- touchy aren't we? ?? I can remember changing the horsecock connection on the F-100 after it had been defueled and the line was full of fuel-about 5 gals worth, changing leading edge cells on T-33s, liquidometers on F-86s before there was such a thing as a fuel system repair guy.... The first guys to get your AFSC were force cross trained tirekickers- without benefit of a "tech school" because they already had the experience..... The Old Sarge Welcome onto our flight line and into our hangar..... Glad to see you go back and read some of the old stuff........
Post by Mark O on Dec 19, 2011 8:43:33 GMT 9
Holy "thread revival" Batman! ZONK!!Welcome to the forums farranb! Looks like you've found your way around. Did you work fuels on Sixes just at Tyndall, or were you in some other Six units? Glad to have you here! Mark (P.S. I can't believe "zonk" isn't in the spell check dictionary. I saw it on Batman all the time!)
Post by LBer1568 on Dec 19, 2011 13:43:59 GMT 9
All of the F-106 folks here and not one single story of getting sprayed with JP-4 from both wing bottoms as engine shut down. Thay was the first thing I learned was not to walk under wings during shutdown. Some pressure relief valve or some such thing. Being MA-1 I never learned much about fuel systems.
Post by MOW on Dec 19, 2011 15:09:57 GMT 9
All of the F-106 folks here and not one single story of getting sprayed with JP-4 from both wing bottoms as engine shut down. Thay was the first thing I learned was not to walk under wings during shutdown. Some pressure relief valve or some such thing. Being MA-1 I never learned much about fuel systems. :rofl yup, you learned real quick where NOT to be. Oh and the drip cans go under AFTERWARDS. :2thumbsup
Post by jimpadgett on Dec 19, 2011 21:04:56 GMT 9
A lot of fuel was dumped into the grated trench that ran the length of the flight line at Tyndall. Made a spectacular show when ignited by (I heard) a tossed cigarette at the end of a smoke break. Can't remember the year.
Post by bear (Deceased) on Dec 19, 2011 23:05:35 GMT 9
Castle 106 on trim pad would not start, bleed the starter into 30 gal garbage can, about the 4th try forgot to move can and got a hot start ground was already covered withfuel, luckey they had fire truck standing by minor smoke to the aircraft. More training.
Boost pump switches being left on always a nice mess to clean up.
Wash down trucks all the fuel down the drains it a wonder the ramps did't blowup.
Bear
Post by shadowgunner on May 11, 2012 15:48:33 GMT 9
Somehow I overlooked this thread. Here's one for all the wpns guys.
I had recently PCS'd to Hamilton's 84FIS. I was a SSgt with a new load crew (1 & 2 stripers) . Having recently certified on 6's, I asked the shop chief who was the best load crew in the shop. He said John McFarland had pretty much the best crew they had. I asked the chief what were we averaging for quickturn times. IIRC, he said about 18mins (and that was with running cursory, installing SEMs on the rails). Hmm, I remember in the 5th we did much better than that!
Days later, we were advised that we were going to have quickturn practices. Well, before we went out to set up the spots, I challenged John to a mini comp. I bet a case of beer (winner's choosing of course) that I could beat him despite being almost 10 years older and running a green crew. Friendly handshakes and off to the races!
The birds rolled into chocks (I still remember the excitement!) and the race started. Somewhere about mid-load something went haywire and the left wing started dumping fuel like crazy. The spot director had to stop the load on my bird and John's crew sailed on to victory!
I paid my due and shook hands with John & his crew and of course gave kudos to my "kids" for a valiant effort.
The shop chief and I chatted later and he mentioned that I had lost and it might have been a hollow boast on my part. I commented that, WE collectively had won, because John's crew clocked somewhere just past 15mins. I had goaded the crews into realizing that they all could be much better than they were.
Da*n fuel spill, I still think we could have beat him! arrgh...
Post by lugnuts55 on May 12, 2012 2:20:08 GMT 9
Iber1568, You reminded me of something that was amusing to anyone watching but not to the man it happened to. There are vents on the bottom of the wings and with a rag over the tip of screwdriver, fuel would get on the rag when the vent was pushed upward. We crew chiefs used the fuel to wipe down the belly of the airplane after a fix or just after a flight. A small leak looked huge by the amount of fluids on the belly.
The thing that was amusing was sometimes, the rag or the screwdriver or something wasn't just right and the fuel would splash onto your cloths and if it was bad enough, you had to go change clothes. The funny thing about it was that it only happened when someone was watching so they could laugh. Oh yeah, it happened to me, too. It's not a fuel spill but the odor was strong.
farranb
FUEL SYSTEM REPAIR
Post by farranb on Oct 22, 2012 4:32:12 GMT 9
Being a 106 fuel repair guy at Tyndall from 1/79-5/81 I remember fuel leaks everytime I had to remove a wing panel to try to fix a part that you couldn't get any more so you had to repair it yourserlf, like using paper clips to repair float valves. It didn't help that Reagan put the clamps on spare parts. After TAC took over and the F-15's were about to come in I was glad to catch the next flight to the Philippines for the next four years.
Post by Jim on Oct 22, 2012 10:54:28 GMT 9
farranb, The Viet Nam War was over with the cease fire on 28 January 1973..... This is the last date for eligibility for the Viet Nam Service Medal.. If you did serve "in country" between 29 Jan 1973 and 29 April 1975, you were not eligible for award of the VN Service Medal..... Viet Nam Vets are identified by the pictured ribbon.. There was one 24 hour period where the medal was awarded that fits in your service time- 29 April 1975-30 April 1975 for "Operation Frequent Wind" en.wikipedia.org/wiki/Operation_Frequent_WindThere was a politician who said he served during the Viet Nam war, implying he was a Viet Nam Veteran.... Please remove the Vietnam era veteran and post basic training/ tech training periods..... I had been retired a few years when Desert Shield and Storm came about... Thanks for serving in those 2 wars, for wars they were and not Conflicts..... Jim Attachments:
Post by Deleted on Oct 22, 2012 12:23:30 GMT 9
Being a 106 fuel repair guy at Tyndall from 1/79-5/81 I remember fuel leaks everytime I had to remove a wing panel to try to fix a part that you couldn't get any more so you had to repair it yourserlf, like using paper clips to repair float valves. It didn't help that Reagan put the clamps on spare parts. After TAC took over and the F-15's were about to come in I was glad to catch the next flight to the Philippines for the next four years. I was an instrument repair guy at McGuire in the 539th from 64/67. I cant remember how many times I pulled my own fuel panels to check fuel probes that were giving false readings upstairs. Including the time I refused to pop the commander's bird due to an electrical storm in the area. I can remember the total number of fuel guys who were there, ZERO. There were two people there in the fuel pits in the middle of the night; me and another guy from my shop. Dont know what cross you're carrying, but there was plenty of misery for everybody if you let it bother you. So, please, dont piss in my beer, or anybody elses on this forum.
farranb
FUEL SYSTEM REPAIR
Post by farranb on Oct 24, 2012 5:27:31 GMT 9
First off, Jim, I'm not real sure what you're talking about, but I'm sure you don't have a clue what you're talking about. You may want to fix the short between the headset. I believe you're saying I'm not a Vietnam vet. Never said I was. Try slowing down and reading it again. It says Vietnam E-R-A Veteran. That's why I am a member of the VVA, are you? You need to go back and read about Vietnam Era Veterans and then come back and give me a lesson in blah-blah-blah...
Next, postalron, you and your buddy's are the exact reason the Air Force put hugesrequirements on us to the point that we had to get tanks open, purged, and safe for people like you. You instrument guys were terrible when it came to troublshooting your system on cargo planes especially with foam. Let's start a thread like, what's your funniest story about people that were maimed or killed in the process of fixing a fuel problem. Fuel spills and fuel repair in general was and is a dangerous business.
