Post by MOW on Feb 1, 2013 20:48:47 GMT 9
Take a look at your mini-profiles.
I've installed the plug-in and it seems to work ok. I'm working with the developer of that plug-in to see how to configure the size and location of the fonts, but it seems to be working. I set the time limit between giving karma at 5 minutes... for now.
Post by lindel on Feb 2, 2013 8:14:36 GMT 9
And just for that...
Post by lindel on Feb 2, 2013 11:35:29 GMT 9
MOW, I'm really liking this newer version of the board. Lots of nice short cuts for us. Thanks!
Post by MOW on Feb 2, 2013 11:46:14 GMT 9
MOW, I'm really liking this newer version of the board. Lots of nice short cuts for us. Thanks! thanks tons... I kinda like it myself. It's a hellavalotta easier to administer.
Post by MOW on Feb 3, 2013 20:17:14 GMT 9
I think the Karma is working ok now. And you'll notice I found a way to adjust the font size to match the rest of the mini-profile.
Post by MOW on Feb 4, 2013 10:20:00 GMT 9
The creator of the Karma system made an adjustment and put out a version upgrade based on our complaint on the broken number increments. This new version supposedly fixed that and also gives me the option to move the Karma: tag in the mini-profile to the bottom... which I like.
Let me know if anyone sees any problems with it.
Post by Jim Scanlon (deceased) on Feb 4, 2013 13:55:16 GMT 9
The creator of the Karma system made an adjustment and put out a version upgrade based on our complaint on the broken number increments. This new version supposedly fixed that and also gives me the option to move the Karma: tag in the mini-profile to the bottom... which I like. Let me know if anyone sees any problems with it. One problem I noticed is the number of Karmas. For instance, MOW, you are only showing ONE Karma, and I know on the old system you had quite a few more. Jim Too
Post by Mark O on Feb 4, 2013 14:02:15 GMT 9
The creator of the Karma system made an adjustment and put out a version upgrade based on our complaint on the broken number increments. This new version supposedly fixed that and also gives me the option to move the Karma: tag in the mini-profile to the bottom... which I like. Let me know if anyone sees any problems with it. One problem I noticed is the number of Karmas. For instance, MOW, you are only showing ONE Karma, and I know on the old system you had quite a few more. Jim Too Don't you remember? One screw up wipes out 10 "atta-boys", so it's just the system catching up with us all! Actually, I think the new version is starting from scratch.
Post by MOW on Feb 4, 2013 15:27:21 GMT 9
Yea, we're starting from scratch. The old Karma did not migrate over because it was an add-on, which we now have plug-ins for, which are much easier and efficent to use and reinstall.
Post by pat perry on Feb 4, 2013 23:34:20 GMT 9
Yea, we're starting from scratch. The old Karma did not migrate over because it was an add-on, which we now have plug-ins for, which are much easier and efficent to use and reinstall. MOW, the former Karma was labeled +Karma / -Karma and the new one says Karma Exalt. Is there only one selection now? Just wondered because the new one is "hot" on both words indicating one selection is available. Pat P.
Post by MOW on Feb 5, 2013 10:33:46 GMT 9
MOW, the former Karma was labeled +Karma / -Karma and the new one says Karma Exalt. Is there only one selection now? Just wondered because the new one is "hot" on both words indicating one selection is available. Pat P. Pat - Yea, I had taken the -Karma (Smite) away thinking do we really want the entire membership to be able to take karma away? But I put it back in again for now.
