chr2011
Post by chr2011 on Feb 17, 2011 23:03:48 GMT 9
Dear Sirs:
In my opinion, the F-101 is one of the coolest century series fighters.
But I guess what makes me like the F-101 so much is the way it looks.
But, I was very curious to know what F-101 pilots thought about its performance.
The F-101A had guns, and I was curious if it was intended to be a dogfighter. Could the F-101 perform ACM well?
Thanks,
Chris
bigron427
Molon Labe
Retired: USA NBA: Decline to state (Sacto Kings) NFL: Die-hard Rams fan MLB: Go Blue!!!
Post by bigron427 on Jul 15, 2011 11:19:40 GMT 9
Good evening!
I have more questions than answers about the F-101 myself, since the last one was retired from the ANG while I was still in high school. However, I've been doing some research off-and-on over the years, so I'll take my best crack at your question. Most of my numbers are from crunching performance data listed in "Standard Aircraft Characteristics, F-101A, Nov 62".
There are two main things to look at to give a quick indication of maneuvering performance. The first is thrust loading, which gives an idea of sustained maneuvering capability (in other words, as the wings bleed energy in a hard turn, is there enough thrust to either maintain that energy or provide any extra energy needed to sustain a tighter turn). The second thing to look at is wing loading (in other words, since wing area translates roughly into available lift, how much lift can you produce, quickly, to make a maximum instantaneous turn.) Wing loading also gives a good yardstick of sustained altitude ability and the ability to maneuver at altitude.
The F-101A is an advanced derivative of the earlier XF-88, designed just after World War Two and first flown in the spring of 1949. I will use performance numbers from the XF-88A, equipped with afterburners, for comparison with the F-86F. Overall, the original design looked to be quite maneuverable. Military trhust loading of the XF-88A ranged from 0.30 to 0.34, versus 0.33 to 0.40 for the F-86F-20. Not quite so good but given the massive size of the XF-88, not too shabby. With afterburners, thrust loading increased to between 0.39-0.45 so in theory, it would have had better sustained maneuvering performance than the F-86. Wing loading at combat weight for the XF-88A was 53.0 lb/sq ft versus 51.6 lb/sq ft for the F-86, so instantaneous turn performance and altitude capability would have been comparable. So for a big plane, the XF-88 would have gotten aroung corners quite well.
However, the XF-88 fell short in range, combat radius, fuel capacity, and altitude capability. With a combat ceiling of just under 42,000 feet, it would have been adequate to escort B-29 and B-50 bombers, but would have barely been able to stay up at combat altitude for the B-36, much less maneuver against MiGs with a ceiling comfortably over 50,000 feet. The idea was to improve capability with a minimum of redesign. McDonnell designers kept basically the same wing plan form, made the wing section thinner for better transonic performance, and lengthened the fuselage to make room for more fuel and much larger engines. Since the landing gear could no longer fold into the fuselage, it was moved further out on each wing and an inboard section added to the wing planform to make room for landing gear and relocated flaps, and to help the thinner wing better resist twisting due to increased aerodynamic loads at transonic and supersonic speeds. The result was an airplane with much, much higher thrust, but kept in the air by basically the same wing area. You can imagine what this might have done to the maneuvering performance of the F-101A.
Bath time for my little girl...more to follow shortly!
Ron Easley
bigron427
Molon Labe
Post by bigron427 on Jul 15, 2011 12:37:08 GMT 9
So, again, just looking at the raw numbers for the F-101A: Thrust loading in military power (internal fuel only) was 0.48-0.52, and in afterburner 0.71-0.76. (In the fall of 1954, this thrust-to-weight ratio was completely unprecedented.) Wing loading at combat weight was 107.3 lb/sq ft, more than double that of the XF-88. Combat ceiling was 49,450 feet, but this was only achievable in afterburner. In the mid-1950s, the primary interceptor for the Soviet Union was the MiG-17F FRESCO-C. Military thrust loading was a bit higher (0.49-0.55), and somewhat inferior in afterburner (but still a very respectable 0.63-0.72). However, wing loading was much, much lower at 42.7 lb/sq ft, which went a long way towards giving the MiG-17F a combat ceiling of over 54,000 feet. That's just looking at raw numbers, let's look at some specifics of the F-101.
At high altitudes, to produce enough lift to stay up there, it has to fly at a higher angle of attack to produce enough lift to balance the weight of the aircraft. Of course, a wing has a maximum angle of attack that it will work up to. Exceeding that angle the wing will stall. Approaching that point, you will experience buffeting and a very turbulent wake of air trailing behind the wing. If this turbulent wake of air happens to pass over the pitch control surfaces, they quit working as intended and, in the case of swept-wing airplanes, you get a phenomenon called "pitch-up" where the nose suddenly pitches up, slices over to one side, resulting in departure from normal flight conditions. Not good, and it would really, really suck if encountered when someone else is shooting at you.
Pitch-up is an inherent disadvantage of any swept wing. McDonnell engineers recognized this very early on, and conducted wind tunnel tests to examine the effects of stall plates (or if you prefer, "wing fences") on wind tunnel models of the XF-88 in 1947. Stall plates would essentially control and smooth the airflow over the wing and keep the wingtips from stalling at high angles of attack. They were used on the XF-88 and carried over to the F-101. So, the tendency to pitch up was recognized very early in the game. The pitch control surfaces on the XF-88 were positioned low on the horizontal stabilizer, and at modereate to high angles of attack were in the turbulent flow field of the wing. Wind tunnel testing showed that increasing vertical stabilizer area by adding a ventral fin helped stability in both the roll and pitch axes, equivalent to raising the vertical stabilizer by 70 inches.
When they redesigned the Voodoo into what would become the F-101, the extremely high exhaust temperatures of the bigger engines demanded the use of titanium keel plates to protect the underlying fuselage structure. In 1952, nobody knew how to build a ventral fin out of this very new material (the F-101A was the first aircraft to make use of significant amounts of titanium.) So, to get the increased stability benefit and to offset the destabilizing effect of the longer forward fuselage, McDonnell engineers moved the vertical stabilizer up as far as they could on the vertical tail, as it turns out, about 70 inches. Dandy. But what they ended up with was, at very high angles of attack, particularly at very high altitudes or low speeds such as during takeoff or landing, the very turbulent wing wake would blank out the tail surfaces even worse, and put the Voodoo into a deep stall, usually ending up in an inverted spin, and did so with very little warning. That killed some very, very good and experienced pilots during flight testing for the F-101A.
Changes to the flight control system and very thorugh training helped minimize accidents, but between the raw performance numbers and the unique characteristics of the F-101A, its dogfighting performance was minimal. Given that, by 1952, the primary mission of the F-101 lent equal emphasis to the delivery of muclear weapons. By the time it entered service in 1956, that was really its only mission. The guns were kept because, in theory, it was tasked as an escort fighter, but in USAFE service they were rarely used and poorly maintained. Just simply not a part of their real-world mission. Its a shame because it was equipped with a pretty good radar with an AN/APG-37 unit with auto track capability, tied into an MA-7 fire control system, and that at lower altitudes the F-101 actually handled very well and was regarded as a good gun platform. But, again, this was not what it would do in the real world.
So bottom line, if faced with a dogfight situation in an F-101: firewall the throttles, unload, and accelerate away. Worked very well for RF-101C pilots back in the day until the advent of the SA-2.
Anyway, hope this is helpful!
Ron Easley
Post by robync on Apr 25, 2012 11:28:34 GMT 9
Did the USAF specify the wing had to be the same or the plane had to have as much commonality as possible with the -88?
Post by Jim on Apr 26, 2012 0:08:38 GMT 9
Did the USAF specify the wing had to be the same or the plane had to have as much commonality as possible with the -88? Why would it need commonality? ? They only made 2!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!Early birds had a bad habit of entering into what pilots called the JC manuver- It began to porpoise, get of control and the pilot would say Juesus Christ-I am outa here. F-101 Voodoo The McDonnell XF-88 Voodoo was a long-range, twin-engine jet fighter aircraft with swept wings designed for the United States Air Force. Although it never entered service, its design was adapted for the subsequent supersonic F-101 Voodoo. en.wikipedia.org/wiki/McDonnell_XF-88_Voodoo and other google links The 88 was long gone before any of us put on a blue suit!!!!!!!!! Robyn, there are 9 threads counting this one on the VOODOO
Post by Jim Scanlon (deceased) on Apr 26, 2012 5:46:18 GMT 9
The Old Sarge is correct, there was no commonality between the 88 & 101.
The Voodoo was bigger, heavier, had much larger engines, the wings were totally different, as was the empenage, and it was able to go Mach 1, going straight up. The 88 could almost get to 500 Kts.
The only things in common are the general shape, and the builder.
There are also great differences between the early Voodoos and the later models.
They both carried J57 engines, but the B model had a longer burner, which required a rebuild of the aft fuselage. Even then, much of the burner was outside the skin.
The earlier models also carried three 20mm cannons, where the B Model had rockets and missiles.
The B also had a different mission.
The gun toters were SAC escorts, capable of doing some fighting.
The B was strictly an interceptor.
There is much more involved, like the Fire Control System in the B, and a second seat for the GIB.
Lots of differences, even withing the 101 lineup.
Post by robync on Apr 27, 2012 8:57:10 GMT 9
Jim
Quicker R&D time?
Why did McDonnell stick to a similar basic shape and not use an entirely new design?
Jim Scanlon
Why did they make the wings so goddamned small?
Admittedly they had a fairly high aspect ratio for a supersonic aircraft, which allowed it to do okay for such a heavy wing-loading, and the T-tail better rides the downwash and exerts more leverage allowing lower-trim drag levels.
It could fly far alright, it could fly fast, and climb-like a rocket, but it's turning performance wasn't very good, and it's stall characteristics were abysmal.
How much more powerful was that engine on the F-101B
When you said the F-101B having rockets, you mean the Genie, or 2.75 FFAR?
R.C.
Post by Jim Scanlon (deceased) on Apr 27, 2012 10:00:28 GMT 9
Post by robync on Apr 29, 2012 17:01:07 GMT 9
JimScanlon I know the F-101B could carry the MB-1/AIR-2; but the F-101A was to have provision for rockets and 3 x Falcons. That's why I was confused
R.C.
bigron427
Molon Labe
Post by bigron427 on Jun 20, 2012 11:31:10 GMT 9
To answer R.C.'s question about armament:
The first F-101B pre-production aircraft were tested with a six-Falcon configuration. By then, the Air Force had made up its mind that it wanted Genies on the aircraft. Several pre-production F-101As were retrofitted with to flight test components intended for the F-101B and given the informal designation "YF-101B" by McDonnell. One of these aircraft, 53-2436, was modified with a working rotary armament door with dummy missiles for test purposes, including tests with Genies.
By the time the F-101B came into service in 1958, they ditched the 6-Falcon armament and went with a standard configuration of 2 Falcons and 2 Genies. Initially, it could carry either SARH ir IR versions of the Falcon, but after about 1961, they removed capability for the radar-guided GAR-1D and went with straight IR missiles.
There was a photograph of the test "YF-101B" aircraft, 53-2436, that was published in Flight magazine in 1956 showing three Falcons and two six-tube rocket launchers on either side of it. This was solely a test fit. In fact, the Falcon was never intended for the F-101A. It was intended as a "strategic fighter" with three basic missions: Bomber escort using guns ( 4 x M39 20-mm), nuclear-armed "intruder" missions against Soviet air defense and strategic forces (the original armament was to be the McDonnell Model 96 weapon/fuel pod with MK 5 warhead), and air defense of forward-deployed bombers at overseas bases. If I can figure out how to post photos on the message boards here I will be very happy to do so.
Hope this helps!
Ron Easley
bigron427
Molon Labe
Post by bigron427 on Jun 20, 2012 11:37:47 GMT 9
Here are photos of 53-2436 with two different armament configurations on the rotary door. Ron Attachments:
bigron427
Molon Labe
Post by bigron427 on Jun 20, 2012 11:40:49 GMT 9
Second photo with the Falcons, which apparently got dropped from the first message.... Ron Attachments:
Post by MOW on Jun 20, 2012 19:48:11 GMT 9
Post by MOW on Jun 20, 2012 19:52:48 GMT 9
To answer R.C.'s question about armament: The first F-101B pre-production aircraft were tested with a six-Falcon configuration. By then, the Air Force had made up its mind that it wanted Genies on the aircraft. Several pre-production F-101As were retrofitted with to flight test components intended for the F-101B and given the informal designation "YF-101B" by McDonnell. One of these aircraft, 53-2436, was modified with a working rotary armament door with dummy missiles for test purposes, including tests with Genies. By the time the F-101B came into service in 1958, they ditched the 6-Falcon armament and went with a standard configuration of 2 Falcons and 2 Genies. Initially, it could carry either SARH ir IR versions of the Falcon, but after about 1961, they removed capability for the radar-guided GAR-1D and went with straight IR missiles. There was a photograph of the test "YF-101B" aircraft, 53-2436, that was published in Flight magazine in 1956 showing three Falcons and two six-tube rocket launchers on either side of it. This was solely a test fit. In fact, the Falcon was never intended for the F-101A. It was intended as a "strategic fighter" with three basic missions: Bomber escort using guns ( 4 x M39 20-mm), nuclear-armed "intruder" missions against Soviet air defense and strategic forces (the original armament was to be the McDonnell Model 96 weapon/fuel pod with MK 5 warhead), and air defense of forward-deployed bombers at overseas bases. If I can figure out how to post photos on the message boards here I will be very happy to do so. Hope this helps! Ron Easley This is from my F-101 sites photo gallery at www.f-101voodoo.com/voodoo_gallery_weapons.htm
Post by MOW on Jun 20, 2012 19:56:01 GMT 9
Ron - email me photos if you want and I'll post them mcgeepj2@hotmail.com
bigron427
Molon Labe
Post by bigron427 on Jun 21, 2012 12:32:59 GMT 9
I've got a lot to send out, but am getting to set go FAR out of town for the next couple of weeks. I'll be very happy to start sending stuff your way when I get back and settled in. I looked over the wikipages and see that some of the entries might need a little work. I will be very happy to forward you information at that time as well.
I have been researching a book on the F-101 off-and-on for about ten years and have just signed a contract to write the thing. I've developed a lot of good information, much of it new.
:yellow-beer
Post by MOW on Jun 21, 2012 14:38:56 GMT 9
I've got a lot to send out, but am getting to set go FAR out of town for the next couple of weeks. I'll be very happy to start sending stuff your way when I get back and settled in. I looked over the wikipages and see that some of the entries might need a little work. I will be very happy to forward you information at that time as well. I have been researching a book on the F-101 off-and-on for about ten years and have just signed a contract to write the thing. I've developed a lot of good information, much of it new. Hell, I'll give you access to edit the wiki pages if you want :2thumbsup Ok, send whatever you want whenever you can, no worries.
