Post by MOW on Mar 3, 2013 16:43:35 GMT 9
We'll use the Snowballs as the example, but here is what you can do with a snowball someone has GIFTED to you or that you have purchased yourself at the ProBoards store. This is a Snowball that you can GIFT away OR use to HIT someone else whereas this is a snowball you've been hit with that turns into a snowman and it's yours forever haha . To GIFT it to someone, which means it is still 'not used', double click your snowball in your Profile and you will see a screen like below. Click the Gift This Badge button and you'll see a screen like the second one. Follow the steps to select the member you want and send them the gift. The screen will fresh when you're done. If you only have 1 snowball to give you will see after the refresh the snowball is now gone. If, however you have more than 1 snowball, such as my 8 in the screenshot, then your screen will refresh and decrease that number accordingly. Now, on the other hand, you can HIT someone with your snowball, which uses it up. Once used, it is gone from your arsenal and cannot be used again. Again, double click your snowball and you will see the same initial screen as before, but this time click the Use Badge Action button. Perform the same steps to select the member you want, but this time there is a Use Action button which is what will throw the snowball. That's about it.
