615crewdog
Post by 615crewdog on Dec 27, 2007 8:39:07 GMT 9
Yes burner runs are dangerous, but that's what makes them fun to most of us who had the privilege of making those full power runs.
ritchie1selfridge
Post by ritchie1selfridge on Apr 14, 2008 1:53:51 GMT 9
An old Msgt I worked for at Selfridge used to describe an afterburner check as "better than $ex and it lasts longer".
deuel
Post by deuel on Apr 23, 2008 9:32:20 GMT 9
I remember that early morning trim pad boogie at Bunker Hill. 319th Barracks was sort of in a line with it even though it was a good distance away but you could hear those run ups and that burner kick in and. Our shop was at the end of the runway and very close to the tarmac. We'd open the door in the MA-Flightline room, stand outside and watch them take off. Man that afterburner... and though the b58's had four engines with burner they just didn't have the sound of the 106. Watching the deltas take off and land was a lot more fun than working on them.
deuel
ritchie1selfridge
Post by ritchie1selfridge on Apr 23, 2008 19:48:28 GMT 9
I spent some TDY time at Bunker Hill (while they resurfaced our runway) and I agree . Nothing like an early morning mission and a pair of "sixes" lighting 'em up.
az09
Post by az09 on May 6, 2008 1:58:34 GMT 9
1970 - Hamilton AFB, Ca - Week-end Stand-by Duty
Once our sister ADC Units found out they had "Qualified" SIX Maintenance in the bay area, we started getting more "transit" F-106's on the week-ends than we maintained through the week. One week-end I counted 26 SIXES with different tail markings than ours. Our 12 man shop was hard pressed to cover our 24/7 duty span.
One example - A pilot from up the coast noticed fuel and thrust fluxes on pull-out from home station. Flew the bird on down to us to change his fuel control. When we asked him why he took the chance of a complete fuel control failure, and not returning to home base, he replied, I wanted to see the "CITY".
OK, I digress. One Sunday we got a call for an AB write up. We go to the plane pull the forms and read, AB won't light at 30,000 feet. Well we knew it was probably an altitude compensator vavle, but there was no way of doing "at altitude" troubleshooting. We changed the valve and asked for towing to the trim pad.
Job control told us we were getting close to the 2200 hours cut-off for Full Power Runs. Our Trim Pad was the first "pea" pad on the other side of the active runway. This old WW2 base still had the original parking area for the old P-40's over there.
I was on a short corded headset, standing ground, while the Ssgt was in the cockpit, running up and checking the system after we had changed the altitude compensating valve.
We finished up around 2200 and Jack was letting the engine cool down at idle/scavenging mode. I start picking up the stuff around me and all of a sudden, Jack says, " They want to call me out at night for a bull s--t write up, I'll let them know I was out here doing their bull s--t work". He starts banging the AB in, then out, in, out, in, out, he cycles the crap out of that big J-75. The booming reports roll out over the bay into the housing area that had been built over there recently. The SIX was bouncing up and down with each lighting, I thought I was going to be hit by the left side drop tank. This plane was jumping and shaking like a "spooked" mustang. I look out across the bay and the house lights were blinking on, until every house was lit up.
Finally Jack cools the engine again and shuts it down. The pad is quiet. Quiet as a church at mid-night. That is if the church had a Job Control telephone box ringing continuously off the hook. Jack yells at me to answer the phone, I replied, "No Jack, I know they want to talk with you." We were directed to report to Job Control as soon as we got back the other side.
Jack got the reaming that he so finely deserved. The MSgt said he was getting calls from everyone, even congressmen. Don't know if that was true, but I'm sure some of those folks had Hamilton Job Control on "speed dial" after that Sunday.
The next day they found the front landing gear strut was leaking hydraulic fluid. Jack had ruptured the seals in the strut. That incident coupled with Jack's house jack/ spar breaking incident and him stepping on and bending the aileron control rod, the big ole long rod that goes down the right side of the engine bay thats mechanically moves the ailerons. This guy was personally responsible for year long grounding of 2 SIXES. So, he was reassigned to Job Control, away from the modern mechanical equipment.
az09
Post by az09 on May 6, 2008 2:21:46 GMT 9
1967 - Dyess AFB, Tx - C-130E / T-56 engines
During the build up of troops for the war in SE Asia our branch was having a large training problem getting us young troops up-graded. So the Branch Chief, CMSgt Wiley H. Watkins decided we would rotate from section to section within the Branch until we up-graded. Then when this 3-level to 5-level move was completed the in shop guys could take their engines to the Test Cell and be part of the run team and fix anything that was wrong. This worked out grand. The manning at the Cell was just 2 people a Sgt and a TSgt.
My turn at going to the Test Cell opened my eyes to many things about the maintenance of T-56 engines and the portable test cell.
We were located right next to SAC Test Cell. They would run up the J-57's for the KC-135 and B-52's. I noticed that after they serviced the engines with oil they would take the cans and throw them into the exhaust stream of the operating engine. The can would collaspe and be shot into the neighboring farmers field. Yes SAC leads the way in recycling!!!!
burt49
Post by burt49 on May 5, 2010 11:29:13 GMT 9
You get a scramble with all the birds lined up in an elephant walk. The first bird is just lifting off, the second is in the middle of the runway, the third is just hitting burner, and the fourth is ready to pull onto the runway. In a few minutes all the birds will have had their burners bright in the dark Griffis sky. Airplanes are a lot of work but they sure are fun. When I got out I spent a year in the National Guard blowing up old trucks and cows with 105 howitzers at Avon Park Bomb Range. Going from the crew chief of a 106 to the section chief of a 105 howitzer is a culture shock at best. Being prior military, I only had to stay in was one year, and that was all I needed to get the point. God Bless the Grunts! B McKee USAF
Post by lugnuts55 on May 5, 2010 23:11:55 GMT 9
I never got a ride in a 106 but I did go to the trim pad in the back seat of my B model. The engine shop guys were adjusting this and that after an engine change and I couldn't wait for the AB test. When it came time to lite the burner, I was expecting a jolt. Jolt is not the word for the experience. It was fantastic. I had a grin on my face all the way back to the flightline and it would not go away. It was awesome. Feeling the power of the engine pulling on the cables was something I have never experienced before or since. We bounced around a few times and the adjustments were made. It was over much too soon for me.
As a side note, I was told on two occasions that I was going to get a ride in my B model and both times I was outranked at the last minute. I was already fitted for a helmet and mask and had a flight suit. Was I disappointed? Damn Right!!
Post by Bullhunter on May 6, 2010 0:48:24 GMT 9
lugnuts, I know exactly how you felt about missing out on F-106 flight. I was tasked to go TDY from McChord AFB, WA to Kingsley Field, or to work on a F-106A that had flamed-out on the taxiway when it came back from a scramble. WE were to have taken our B-model F-106 but the night before a eager swing shift pulled it in the hanger and depaneled it for phase inspection that was starting Monday morning. So we ended up taking one of our T-33's. It was a nice flight banking around the clouds.
As for the F-106A that flamed-out. It was already fueled and tied down on the trim pad. I ran the crap out of it with lots of afterburner time. I'm sure Klamouth Falls folks wonder what was going on. I discovered that the right wing was not feeding fuel to the engine. Only the left wing was. Couldn't figure how that was not noticed in flight by the pilot. Center of gravity must of been mess up and flet strange to fly. Not to lay this all on the pilot, maintenance did not mention that the right wing was empty and no write-up in the 781 maintenance forms either about the fuel, just a flame-out. ?
cc790
F-106 '80-'84 F-15 '84-'01
Post by cc790 on May 7, 2010 21:05:53 GMT 9
I had the same thing happen to me. We had one come back from DM on a Saturday. It had a burner no light on take off.
We took it to the trim pad on Sunday morning. A beautiful cold Sunday morning!
I ran an entire load of fuel through it just going in and out of burner. No defects. Taxied back, put her to bed, and went to the break room to do the forms.
Our squadron commander walked in and asked who was running the bird on the trim pad. I fessed up and he told me he was in church and the priest had to quit giving the sermon because the burner was so loud. He said he counted a minimum of 40 burner lights!
In one of my dumber moments, I told him half jokingly that I would have done more but I ran out of gas! He was not amused and pulled my run license on the spot!
Post by Bullhunter on May 8, 2010 2:21:10 GMT 9
Post by lugnuts55 on May 8, 2010 4:40:55 GMT 9
Sometimes it's only funny if they do it.
cc790
Post by cc790 on May 9, 2010 2:06:00 GMT 9
What can I say? I was a nineteen year old two striper! : It turned out OK though. I got my license back the following day. I was one of two run qualified guys at the time.
burt49
Post by burt49 on May 26, 2010 11:56:21 GMT 9
Sometimes little things can make a big difference in your life. I intended to spend one hitch in the Air Force and get out. My dad was career Army, and I wanted to put down some roots. The problem is, you can start to like it in USAF. As some of the other guys got short, they were given a ride in the B. What a hoot to be offered something like that. When it came my time to meet with Col McWhorter, he said "Burt we are just to far behind to take you up". I never said anything to him or anyone else, but the ride in a "B" would have been the deciding factor. Who knows what might have been. The subject is not reupping, it is about hitting the afterburner. Before I became run up qualified, I did one of my (thank goodness few) dumber moves. The job was to take a bird back to the hanger. I was having a hard time pushing one of the pins out of the cable, and was too lazy to go get my screwdriver. Dumb me used my finger to push out the pin, and sure enough the pin came out. Yeeooowww! my finger was now now in the hole and I just knew I was going to lose it. Another crew member rushed over and called for everyone to push the nose of the bird in such a way as to drop tension on the cable. When the did, I was able to pull a very swollen finger out. Although it was an opportuntiy for the guys to get back at me for some of my practical jokes, everyone knew I had been humbled pretty good. The birds were great when you were running them up, you just had to remember to focus on safety the entire operation. B McKee USAF
