Post by Jim on Feb 17, 2012 0:55:02 GMT 9
believe I have a replica placard downstairs - will measure and will post it........... The Old Sarge
sixfixer
Post by sixfixer on Feb 21, 2012 22:39:10 GMT 9
Hello Diamondback - -
The Armament placard worn by the Six was 10" X 16" (with a 1" border).
Keep in mind the Drendel artwork of Balls 4 is very good, but it is a drawing with some imperfections (in my opinion the stripes are a little thick). But using that piece with pictures will certainly give you a great representation of the stripes.
Post by Diamondback on Feb 22, 2012 7:19:11 GMT 9
Thanks, Ernie! So, if the Drendel stripes are thick, and the total placard over outside edging is 18", I'm thinking a 6" figure per stripe ought to work. (If only I could find an original Fowler sheet or build with it applied to measure from...) 1/8" seems awful small for that area, but if I could find tape the right width... (Great, now I'm having flashbacks to high-school Algebra! Guess mocking it up in SketchUp will work as a shortcut... if somebody had a really good model of a Six for it I'd consider digitally "slicing it up" along the stripe edges and using that to generate masks, or better yet artwork for an ALPS so all I'd need to lay down with paint would be a white base.)
I've also seen photos of 0057 as Ops O's bird with just the blues, to add a little more data to the mix, but each of its two looks broader than 004 or 0054's, my gut says "about same area covered".
billstoops
Retired: USAF
Post by billstoops on Feb 25, 2012 5:25:24 GMT 9
I have a picture of the 318th birds flying with the command aircraft. I don't know how to post it. give me your email address and I will email it to you. Bill Stoops
sixfixer
Post by sixfixer on Feb 25, 2012 5:50:03 GMT 9
Hello billstoops - I'm the webmaster of a page dedicated to the 318th FIS ( www.318thfis.com/ ) you wouldn't mind sending it my way as well - - My e-mail address is sixfixer@yahoo.com. Thanks ! Ernie
Post by pat perry on Feb 25, 2012 6:27:16 GMT 9
I have a picture of the 318th birds flying with the command aircraft. I don't know how to post it. give me your email address and I will email it to you. Bill Stoops Welcome aboard billstoops This thread will show you how to post a picture. There are several ways to do it but the simplest is to use the feature that's built into the forum. forum.f-106deltadart.com/index.cgi?action=display&board=tip&thread=2291&page=1#20268Pat P. :welcome
Post by Bullhunter on Jan 25, 2018 14:31:39 GMT 9
Many of the old WWII post cards are better than todays as art work goes.
billstoops
Retired: USAF
Post by billstoops on Dec 31, 2019 7:51:49 GMT 9
I did not know them. I left Selfridge Dec. 65 to go to Viet Nam.
Post by pat perry on Sept 19, 2020 8:39:21 GMT 9
Gary, Challenge Coins are two sided. If there is a rare one it may be a short run special edition. Pat McGee can answer this question. Here is the current copy of Pat McGee's estore selection. www.f-106deltadart.com/estore/Thanks, Pat P.
Post by Bullhunter on Sept 19, 2020 9:08:01 GMT 9
Gary, Challenge Coins are two sided. If there is a rare one it may be a short run special edition. Pat McGee can answer this question. Here is the current copy of Pat McGee's estore selection. www.f-106deltadart.com/estore/Thanks, Pat P. I've purchased from his estore before. Looks like his keychains have about doubled in price. I have ordered quite a few as gifts and don't recall paying that much. I could be wrong, been wrong before. OK Jim, can you spot the difference ? EDIT: Gary are you talking about the Dragon's fins are white on one coin and blue on the other? I don't know which one is correct, white or blue. One coin could be a shot of the proof before production that was rejected and corrected to the correct color. Just guessing. Oh BTW, I edited this because if I Quoted it would lose the earliest post. Pat P.
